o2's confused front and rear
. They took out the cats welded in four bungs and put 2 and 2. I believe they just put them in not caring which ones went first. The only prob now that I did my hooker LTs theres only two bungs instead of 4 and I need to make sure I've got the right o2's plugged in. On the passenger side that harness that carries the wires for the o2 also seems to carry some wire for the starter correct? On the drivers side I'm kinda confused theres a plug up by the front by the rack n pinion alternator area. Would this be the harness for the front o2 or no? because there is also another plug for an o2 right by the tranny on the driver side and also I believe on passenger side. On passenger side I believe the plug by tranny also carries a plug for the tranny and the o2 as well? I just need someone to tell me what other wires are carried in the groups of wires that have the front o2 harnesses in them. Thanks
