Single Chambers on True Duals vs. Bullets
TSPENCE, post up your outside vids of your car.
2nd gear hit at 4k
http://www.youtube.com/watch?v=DNmnWZiXXfo
Putting around the neighborhood with a Yank4k
http://www.youtube.com/watch?v=bcZGEd0AYDE
shows my setup at different RPMs before the cam install
http://www.youtube.com/watch?v=5obrqHQy1qc
outside
http://www.youtube.com/watch?v=K2Vy0Suuuhg
from inside car at track (that vibrating sound is my plastic cam mount)
http://www.youtube.com/watch?v=8fdEL__qK20
http://www.youtube.com/watch?v=P035w6zpw1g
http://www.youtube.com/watch?v=bOex9OAjLeo&NR=1
.Just recently took out the BFH and installed a pair of Hooker Aerochambers at the rear bumper and it is much nicer. Still sounds mean; but slightly mellower and deeper.
Then there are the dual 3" electric cut-outs when I want to sound like an Outlaw car
. The Best V8 Stories One Small Block at Time
You can settle for flowmasters and be like everybody else or Borla XR-1s and be different.
http://www.youtube.com/watch?v=kzVrhe0D0oU
After my long tubes I had flowmaster 1 chambers clamped onto the headers directly no H or X as a temporary exhaust. sounded really wicked but as you can imagine crazy loud and lots of resonance inside the car because it was dumped pretty much under the seats.. lol. Vid.. http://www.fquick.com/videos/Exhaust...1_Z28_LS1/3690
When I had the cash I bought some 3" tubing and welded up a TD setup dumped at the axle with again flowmaster 1 chambers no cats. I loved the sound of them and was not as loud in the car very deep and would set off car alarms at idle. The interior resonance was still unbearable. I daily drive the car in all weather as its my only car and with a 4000 stall it was impossibly to stay out of that resonance point. Another problem I had was ground clearance. I could only get about 2" under the mufflers and they got beat up quick. I ended up selling the exhaust after a short time.
Then came the sweet thunders... First setup was a 2.5" setup no cats into short Powersticks dumped at the axle. Resonance was almost completely gone, it as not as deep but I still loved the sound and because of the small size of the mufflers I tucked it all up super tight so no more clearance issues. going over speed bumps. I have a vid of that I made...
http://www.fquick.com/videos/2_5_quo..._mufflers/6216
Then I changed it again.. this time just a change to 3" pipe off the headers with a nice gradual neck down to 2.5" after the H pipe. Sound was the same I was just after a smoother transition from 3" to 2.5". Then I got tired of the no Cats smell wafting into the car when in traffic and put some Magnaflow 3" cats on which is where I'm at now and have no inclination to change it again.
pass with Spintech Super Pro streets
http://www.youtube.com/watch?v=n7tIS...eature=channel
pass with bullets
http://www.youtube.com/watch?v=1cZ_6...eature=channel
I love the spintechs.
