smell
Old May 5, 2010 | 12:04 PM
peterock98's Avatar
Default smell
My car has a coolant smell when driving and its just a strong smell that goes away with in 10-15 seconds. The radiator cap ,waterpump and the heater core are all new?I m swapping out parts and it's not helping.J F Pontiac installed cartek stage 2 heads and cam with a ported ls6 intake .My car is a 98 how do they run the coolant cross over pipes at the back of the motor when they install an ls6 intake ? Also my coolant level is not dropping and if i run the car let the car idol with the radiator cap for 10 minutes i see steam vapor coming out.
Old May 5, 2010 | 06:13 PM
SOMbitch's Avatar
You grind the bottom of the intake with a dremmel....
Old May 6, 2010 | 10:31 AM
peterock98's Avatar
Mine has the ls6 coolant crossover tubes.Its problely making steam @ the top of the heads cause the back is plugged....
