De-screening you MAF?
Old May 10, 2010 | 05:58 AM
tg580's Avatar
Default De-screening you MAF?
I have heard guys on here talking about de-screening their MAF. How do you do this. Exactly where is this screen? What gains do you see?
Old May 10, 2010 | 06:00 AM
69LT1Bird's Avatar
Leave the screen in the MAF. You will not see any measurable gains and actually may introduce issues. It is there for a reason, it straightens out the airflow to direct the air over the sensors.
Old May 10, 2010 | 06:10 AM
86zcamaro's Avatar
I agree dont take it off, it actually stops debris that makes it past the fliter, my car was horrible about that when I first got it and changed the filter, had to clean all of it off the screen.
Since that it hadnt built up any but its possible for stuff to get through, be it something harmful itd be costly I would think
Screen is at the front of the mass air flow sensor, your better off buying a bigger one if your that worried about flow through it. Although everyone on here says the slp one isnt any good mine hasnt had issues.
Old May 10, 2010 | 06:17 AM
bene's Avatar
Trunion King
I have descreened ported MAF ends with mine however I got it tuned.
Old May 10, 2010 | 06:18 AM
1sicZ's Avatar
Yep, not a good idea to mod the stock MAF
Old May 10, 2010 | 09:47 AM
Frogger's Avatar
Ok so you want to remove the screen in the MAF? Do it. Its useless. Straightens out flow? I think our intake tracts are already straight as can be. They are 'common' parts on truck motors that have a hella bent intake tube design. Think they protect? Try finding a screen on a higher dollar zo6
Old May 10, 2010 | 09:52 AM
udienow's Avatar
I bought my car with the MAF already de-screened. The car runs great. But idk if I would have done this mod myself if it wasn't already done.
Old May 10, 2010 | 10:07 AM
mikey67's Avatar
I wouldn't remove it. It's purpose isn't neccessarily to "straighten" the air flow. It diffuses the air flow/lessens turbulence, and creates a more consistent volume of air across across the MAF and it's sensors. Removing it may or may not cause surging or idle problems... I doubt you would feel any difference from a performance standpoint, but it's your car so... YMMV
Old May 10, 2010 | 10:45 AM
AnnivSS's Avatar
Take it all with a grain of salt. I descreen and ported my maf. My car saw a .2 1/4 mile gain but on the dyno it detonated above 5000rpm's. I was pulling 5 counts of knock (max on a stock ls1 from what im told). On the street it doesnt seem to detonate as long as I make sure I get good fuel. Everything the local tuners have told me is the factory MAF in factory form is perfectly fine unless youre looking for much higher hp numbers or boost. I plan on throwing a stock maf back on mine shortly.
Old May 11, 2010 | 12:20 PM
Frogger's Avatar
Nice technical explanation. However AnnivSS you also ported your stock maf increasing the total amount of air coming in. Our PCMs can only adjust so much w/o a tune. Thats why so many of us get a tune with just intake, headers and exhaust.
Old May 11, 2010 | 03:18 PM
blackfang's Avatar
Leave the MAF alone. You won't even notice any real gains and could very well introduce issues.
Old May 11, 2010 | 04:21 PM
Arc00TA's Avatar
I think this is the right answer here. I have had it both ways, I ported one and removed the airfoil in the middle and the screens, and it showed no real difference from the stock setup. The chance of causing a problem outweighs a tiny hp gain you might see. We don't drive hondas here, no need to dig for 1hp gains.
Old May 11, 2010 | 10:12 PM
sjsingle1's Avatar
the stock replacement GM MAF has no screens............go figure
Old May 11, 2010 | 10:56 PM
RevGTO's Avatar
Pontiacerator
Geez ... this subject is older than Moses. I've had three LS1 cars and each one had crap on that screen when I pulled it to inspect.
Add that to the fact that there are no gains from doing it ... why bother?
Old May 11, 2010 | 11:13 PM
Driftunit's Avatar
take it off and put your hand behind it and blow through the screen... then move it away and do the same to your bare hand.. if that difference feels worth it then do it. i took mine out and had no probs at all, id suggest it but im no mechanic
Old Jun 10, 2010 | 07:11 PM
434strokergt45r's Avatar
Banned Scammer
i would not do it your not going to gain anything you might suck somthing up and hit the probe in there
Old Jun 10, 2010 | 07:21 PM
LS1-450's Avatar
OMFG, there's only 50,000 threads in the archives about this. Straightening air is bullshit. The reduced area that the screen creates speeds air velocity under low intake air velocity conditions such as @ idle, that's it.
You can remove the screen as long as you have tuning software to modify the MAF table or have a tuner do it. If you don't tune, it's not ideal, but, fuel trims should balance the difference.
Old Jun 10, 2010 | 08:15 PM
BOBthe4dH8r's Avatar
fwiw i took my screen out when i ported my tb and made my custom intake. it made a noticeable difference in throttle response. but i did all three at the same time so i cant tell u how much of the gain is contributed by the de-screen. my guess is very little tho.
Old Jun 10, 2010 | 09:39 PM
hawiianpwr's Avatar
When I bought my truck back in 02 it was descreened. I bought a stock replacement to get the screen back after hearing some opinions of this site and I couldn't believe how much better it ran with the screen. Definitely keep it on.
Old Jun 11, 2010 | 07:39 AM
69lemansguy's Avatar
mine was descreened before i bought it, i have never had an issue, and the car runs great. BUT if it was on there when i bought it, i dont know if i would have removed it. its personal preference honestly. If you feel like the car will run "faster" or "better" with it descreened, then go for it.
