Compare Nick Williams & PTM 102 mm Throttle Body's
I am getting either the NW 102mm or the PTM 102mm TB. There is only a $100 difference between the two and I just need to know if there is ANY difference between the two ? If not I would for sure save $100 to put towards my FAST 102 intake.
102mm PTM Throttle Body:
http://www.texas-speed.com/shop/item...d=891&catid=73
Nick Williams 102mm
http://hinsonsupercars.com/p-1158-ni...e-by-wire.aspx
Nick Williams 102mm
This is the correct Nick Williams throttle body...
https://www.vengeancerd.com/ecart/pr...-Throttle-Body
as far as the difference I'm not sure. I've heard glorious things about the NW's one... never hear much about the PTM. Not to say it's not a good piece or anything...
Have any of you guys fitted a 102mm tb & how has the tuner gotten on with tuning. I am also looking at the NW 102 tb compared to the PTM 95 with a Fast 102 intake. A guy only gets 1 chance of getting it right on this side of the world so info from you guys is invaluable.
Cheers
Cheers
Yout wont see any benifit from running the 102mm throttle body over the 92mm throttle body on the FAST intake(with your combination).
Just get a 92mm throttle body. I'm running a 90mm TB on my FAST 102.
The 102mm throttle body requires some clearancing either on the throttle body or water pump on F-bodies. The 92 does not.
