85 mm throttle body question
Old May 26, 2010 | 07:57 PM
Quick SSilver 98's Avatar
Default 85 mm throttle body question
Ok my mods are in my sig, How much HP would a 85 MM throttle body give me over the non ported stock one I am running? Would I fell the extra power and would I still have the low end power I have now? Thanks.
Old May 26, 2010 | 08:15 PM
supersick99z's Avatar
Maybe 10hp which is not noticable! Although throttle response may be improved over stock.
Old May 26, 2010 | 08:27 PM
5.3LJimmy's Avatar
Your throttle body is inside your engine?
Old May 26, 2010 | 08:34 PM
Sorry I thought I was on the right page . Maybe a mod can move it for me. Just 10 huh. My intake is made for a 85 MM throttle body so I thought I might get at least 20 HP out of it.
Old May 26, 2010 | 09:00 PM
masterz28's Avatar
I wanted to just ask you that if the new 85 mm tb has a polish to it? I dont mean to change subjects here but can anyone shime in here as to whether they are not and if they can be polished to a mirror shine. I think i would.
Old May 26, 2010 | 10:23 PM
20hp seems a bit much for just a TB, but maybe tuned it would you never know!
Old May 27, 2010 | 08:28 AM
5.3LJimmy's Avatar
10-20HP from a throttle body swap? You guys are crazy! You would be lucky to gain 5HP going from a stock 75mm to an 85mm TB.
Old May 27, 2010 | 08:34 PM
I thought porting the stocker would give me about 5 HP. If that is true then I should just spend my money on something else. O my plan was to get an 85 MM throttle body and run a 85MM plate nitrous system in it would it be worth it then.
Old May 27, 2010 | 08:41 PM
w3s1c0a5t's Avatar
I think im with jimmy on this. Ported stockers are the way to go. I Couldnt really tell any difference but its pretty much free so take it as a win.
The aftermarket ones can give a certain bling factor. So to some its worth it. But if your like me under my hood is dirty anyways hahaha.
Old May 29, 2010 | 01:59 PM
brian_rs/ss's Avatar
85mm tb definitely helped me when doing my build. i have stock 799's and a 224r. made 396 rwhp.
Old May 29, 2010 | 02:17 PM
w3s1c0a5t's Avatar
Helped in what sense?
Old May 29, 2010 | 02:24 PM
throttle response is amazing now, when hitting it from a roll it's violent. part of that is my cam, part of that is the 30 lb injectors, part of it is the 10.5:1 cr, but i'm sure the tb plays a big part in it as well. i'll say that i definitely wouldn't want to put a stocker back on, even a ported stocker.
Old May 29, 2010 | 03:15 PM
w3s1c0a5t's Avatar
uhhm ok.
