ls1 Ground wire location?
Old May 31, 2010 | 02:54 PM
Bad98SS's Avatar
Default ls1 Ground wire location?
Where are the ground wires on a ls1 in a 98 camaro ss, i know there is a steal braided on that connects to the frame on the driver side that comes off of the wiring harness. is there any others and where are they located?
Old May 31, 2010 | 02:58 PM
Unaffliated Racing's Avatar
The main battery ground is on passenger side of the block just in front of the starter and there should be two or three grounds attached to the rear of the driver's side head. That's all other than the one you mentioned.
