Please HELP!!!
Old Jun 12, 2010 | 08:48 PM
Nick_Rapitis's Avatar
Default Please HELP!!!
My car (the one in my sig) has been running great and has nothing wrong aside from a tiny power steering leak but today on my way into work it started running really rough and was kinda "puttering" and the check gauges light was quickly flashing almost in sync with the sound of the engine and the puttering
it has done this two other times now after the first time i noticed it, both times doing it from start up till i turn it off with an occasional second of normal-ness lol
anyone have any idea what the problem may be? my guess is coil pack/spark plug but that's pretty much just a guess... any quick help would be greatly appreciated!
Old Jun 12, 2010 | 08:53 PM
senicalj4579's Avatar
maybe a misfire. plug in a obd and see what it says
Old Jun 12, 2010 | 08:54 PM
or first you can check to make sure all the wires are snaped on. Iv had one pop off on me one time.
Old Jun 12, 2010 | 09:23 PM
yeah the codes wont stay on so nothing pops on on the ODBII... I checked the wires and they are all in, not to say that they aren't a bit old though so who knows
Old Jun 12, 2010 | 09:30 PM
Iv heard of cases that the engine light will blink like that if theres a misfire. You were driving when the car started doing this or was the car doing this when you first started it up?
Old Jun 12, 2010 | 09:35 PM
well i didnt notice for like 3 minutes but it could have been doing it the whole time right after i started it up. the next two times i started it it did it the whole give or a take a second or two where it seemed normal and went right back to crap again...
the car only has like 70k on it if that helps at all...
Old Jun 12, 2010 | 09:43 PM
LS1TA385's Avatar
Yea most likely a misfire, and if the MIL light came on then there will be a DTC set in the system. Sounds like a dead misfire, probably something ignition.
Old Jun 12, 2010 | 09:48 PM
remedy?
 Michael S. Palmer
Old Jun 12, 2010 | 11:24 PM
Gotta find the cause before the remedy. If you were not sure if the car was doing that when you started it the car cant be running all that bad huh? It could be a few things but without a obd code we cant tell you a whole lot.
Old Jun 12, 2010 | 11:27 PM
well at the time it wasnt bad but it is was as soon as i noticed it and has been that way since...I dont have a code reader and dont really want to drive it to autozone as is in case i make something worse...
Old Jun 12, 2010 | 11:29 PM
well you need to do something! Have someone bring you to az and get a obd
