LS6 PCV conversion worth it?
Leave the throttle body hose that goes to the passenger side valve cover.
Block off the holes on the rear of the valve covers.
My car didn't use any oil (or very little) prior to the upgrade and I didn't find any pooling in the intake when I removed it. But I'm one of those guys that likes to do it right the first time. And I consider it sort of "an ounce of prevention..." if you get my drift.
I used the ls1howto.com writeup and the installation went off without a hitch.
Although it is a bit nerve-racking while you're cutting into your block, but its not tough.
I say go for it. Good luck.
Running a breather helps.
