FAST 90 Intake to 102 Intake ,Thoughts?
As for the Hp number.. A 102/102 setup will make more peak Rwhp than a 90/90 setup, it has been proven. On the bigger cube motors, it is even more of a gain. But a stock cube Ls1 will pick up a minimum 7-8Rwhp. For the money, it is worth it to me.
http://forums.corvetteforum.com/c6-t...02-back-5.html
http://forums.corvetteforum.com/c6-t...ost-power.html
A vendor stated, "and I would like to point out what I have told EVERYONE who has called or PM'd me regarding the FAST 102mm. It is intended as a replacement for the 92mm, not an upgrade. It is not intended to be better than a 90 or 92mm, and whether it is a few HP better than the 90/92 or not I would not prod a customer to make that change. It's simply the newest version of the FAST for those coming from a stock style intake looking to get the best composite stock style manifold they can get, just like the 92 was. "
... Until the NEW Fast comes out down the road
Then you need to be looking at a sheetmetal or an itb intake. Any stock style plastic intakes are leaving HP on the table.
Since the runners are removable you could pop in a new set of high RPM runners and make it act like any sheetmetal intake. It would loose torque and gain much more high RPM power....but then you could go back
Been following closely what you guys & Aussie are saying but no one has mentioned anything but the 90/90 or 92/92 swap for the 102
switching the intake alone, and sticking with the same 90mm tb is pointless. you may see a few hp just from the throat of the TB opening being bigger, but the runners and such are nearly identical.
This is no gaurantee that it's your intake manifold, or that you will or won't gain power from switching, but it's a start. If it stays at 98-99 throughout the rpm band, then you might not get much hp gain, or it could be the intake runners that are the restriction.
