02 sensor ?
Old Jun 26, 2010 | 07:36 PM
cory123456's Avatar
Default 02 sensor ?
i put longtubes and a ory on my car, i zip tied the rear 02's up and one fell and got messed up. so after replacing it my cars running like ****. what do you do with rear 02's normally when u put an ory in? and what will make my car run normal again? thanks.
Old Jun 26, 2010 | 09:56 PM
PontiacFan's Avatar
Rear O2's are normally removed when doing the LT swap.
Read, Read, Read some more, ...
How messed up? Burned thru wires & got them crossed?
New one should have been a plug-n-play. Was it?
Seriously, most people have them 'tuned out' by a PCM change in the tune. Got a local dyno shop that can help with tuning?
Or they use O2 Simulators. 'O2 Sims'. All they do is fool the system into a false 'Everything Okay' signal.
Unless the wires were burnt thru & crossed or soemthing, I can't believe that would be the reason for the car to run like crap.
Also, since LT's are 'External Engine', ..., you'll probably get a move to that forum, or more likely to the 'PCM & Tuning' forum.
Old Jun 27, 2010 | 10:45 AM
cory123456's Avatar
my car had them tuned out and was running great then the passenger side 02 wires got cut and my servise engine light popped up so i changed it out and hasnt gone back to normal, is there anyway to reset the codes?
Old Jun 27, 2010 | 11:36 AM
PontiacFan's Avatar
If they were 'tuned out', why were they even still on there?
Did ya try to disconnect the battery for a while?
Have a local repair shop reset them with their code scanner?
Old Jun 27, 2010 | 12:06 PM
cory123456's Avatar
i didnt know u were sapposed to unplug them, i disconnected the battery and that shut off the service light but as soon as i shut it off it comes right back, i took it my local autozone cuz the y can clear codes but their scanner couldnt find anything.
Old Jun 27, 2010 | 01:12 PM
cyberkill's Avatar
If that's what you meant by "tuned out," then the SES light is going to come back after a while -- 30 minutes of driving or so? Tuning is like sending in your PCM to one of the mail order tune guys or going to a shop where they plug into and mess around with the settings.
Like PontiacFan said, with most headers installs, you don't use rear o2s. For instance, I got Pacesetter Headers (probably most common around these parts), and they don't even have the bungs for the rear O2 sensors, so there's nowhere to plug them into.
Old Jun 27, 2010 | 09:02 PM
cory123456's Avatar
My cars tuned by frost, and I had the lt's on for awhile and no ses light came on until the wire got messed up
