Solid motor mounts! Please read!
Old Jul 13, 2010 | 12:39 AM
BFarrier's Avatar
Default Solid motor mounts! Please read!
so i just ordered solid MM and poly Trans like i been told and read you run poly poly or solid poly never solid solid on these cars. now my torque arm i have relocated because im running a short t/a does that mean i can run solid solid for engine and trans or stick with the solid poly? need advise parts will be in friday.
Old Jul 13, 2010 | 01:07 AM
98RedBird's Avatar
Just run the solid/poly. I really see no point in running a solid trans mount.... I didn't even know they made one to be honest.
Old Jul 13, 2010 | 01:18 AM
BFarrier's Avatar
yeah i dont think they made one either i dont know if they do but i know i can fab one up at the machine shop i didnt know they just wanted the poly because originally the torque are was mounted on the tail shaft
Old Jul 13, 2010 | 05:09 AM
Cobras_Rule's Avatar
I would just go with a solid/poly mount just cuz the poly tranny mount is 25 bucks... why go through the hassle of fabbin a solid mount that wont do anything more of a noticeable difference then a poly. Im runnin solid/poly and it works fine.
Old Jul 15, 2010 | 11:43 PM
1FastBrick's Avatar
The reason not to run a solid mount on the tranny is because of chassis flex. Alot of people have actually snaped the transmission case as a result of chassis flex when running all solid mounts.
Run the solid up front and poly at the trans and you will be fine.
Old Jul 15, 2010 | 11:57 PM
X-ray's Avatar
I'm having solid MMs installed but I'm leaving the tranny mount stock rubber. It seems a number of people with a poly trans mount get bad vibrations. There's no harm in running a stock rubber trans mount with poly or solid motor mounts.
So the answer to your question is no, you don't want to run a solid trans mount, even they even exist. Never heard of them myself. You don't even need the poly trans mount.
Old Jul 16, 2010 | 12:01 AM
1FastBrick's Avatar
Usually the poly has a safety built in if it was to ever tear apart. But I Personally have never seen a stock one brake unless it was soaked in tranny fluid or if the exahust was to close to the mount.
Old Jul 16, 2010 | 12:08 AM
Soul Crusher's Avatar
I've got a poly trans mount and the stock engine mounts (for now) no extra noise/vibration from the poly trans mount.
 Michael S. Palmer
Old Jul 16, 2010 | 12:11 AM
areax's Avatar
This is a little off topic, but I have broke 2 factory trans mounts on my stock 99 z28 a4.. I did beat on the car a lot though during that period of time.. but I replaced the trans mount with the same factory mount 3rd time around and it is still doing fine (I haven't beat on the car as much though).
I agree though, poly trans mount should serve the purpose fine.
Old Jul 16, 2010 | 01:52 AM
86zcamaro's Avatar
Supposedly my trans mount is torn and has been since I basically got the car, I bought a new one but the car drives fine and ive run it at the track without problems, so I dont see a reason to change it for now.
When i can get it done for free at the votech I went to this fall I probably will let them do that, shocks and springs.
