FAST 102 install question...another one!!
Old Jul 29, 2010 | 09:01 AM
KBG's Avatar
KBG
Default FAST 102 install question...another one!!
went to install the FAST 102 on my car last night and the only issue I am having is with the vacuum ports on the back of the intake. There are 2 and the large one is obviously for the brake booster and the other is for?????
seems that the HVAC line should plug in there but won't reach??
Old Jul 29, 2010 | 03:15 PM
TooLateVTEC's Avatar
MAP sensor I believe is back there.
Old Jul 29, 2010 | 04:16 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
That should be the hole for the MAP sensor.
Old Jul 29, 2010 | 05:22 PM
KBG's Avatar
KBG
I shouldn't of said vacuum ports...they are outlets rather
MAP sensor is already installed.....so is brake booster hose.......guess I just need to get some vacuum line and extend it so the HVAC hose will meet the other outlet in the back of the intake because there is no way it is long enough now
Old Aug 1, 2010 | 10:49 AM
KBG's Avatar
KBG
Ok tried to bolt this thing down last night and f**ked with the 2 middle alignment bolts for an hour and a half.....I can put the left side in but then the right wont thread......If I put the right side in I can't get the left side in....HELP!!!!
By middle alignment bolts I mean the 2 bolts in the middle on each side that have the sleeves sticking out of the bottom side of the intake
bolting it to a set of TFS 235s for what it's worth
