Help: Acts like hit rev limiter?
Old Jul 31, 2010 | 07:54 PM
tg580's Avatar
Default Help: Acts like hit rev limiter?
When its at the top of first it acts like its hitting the rev limiter right before it shifts. Then it keeps sputtering through 2nd and into third. I don't have a clue what the problem could be, so I need help. Any suggestions?
Old Aug 1, 2010 | 09:08 AM
LS1WS6dreamer's Avatar
If your at WOT, it could be the MAFS.
Old Aug 1, 2010 | 10:46 AM
tg580's Avatar
I'll check it but it was just cleaned about a month ago. Nobody else has any ideas?
Old Aug 1, 2010 | 11:48 AM
TORCHD 02 TA's Avatar
Maybe a bad wire causing a misfire?
Old Aug 1, 2010 | 12:53 PM
ULTIMATEORANGESS's Avatar
id say it transmission related.
Old Aug 1, 2010 | 01:11 PM
garygnu's Avatar
check you plugs and test the plug wires.test all coils for spark.may be a bad crank sensor.
Old Aug 1, 2010 | 05:06 PM
tg580's Avatar
Well, I thought that I found the problem. I went out to clean the MAFS and damned if some ******* had stole my K&N air filter. The sensor that plugs into the lid was unplugged and my filter was gone. The car has only been in my garage and nowhere else. I have thousands of dollars in tools in the garage the car was open and my GTech is right there and the only thing gone was the filter! Anyways I cleaned the MAFS and replaced the filter and it still does it.
Old Aug 1, 2010 | 06:46 PM
DaveX's Avatar
It's possible that it is tagging the rev limiter due to how fast it is building rpm's and how long it takes the trans to shift.
Old Aug 1, 2010 | 09:10 PM
I was thinking that bc there is an offset between the tach and the computer
Old Aug 1, 2010 | 11:04 PM
holy **** man
Old Aug 2, 2010 | 05:22 AM
tg580's Avatar
Does it make sense that it could all of a sudden start doing this? I had it tuned and it has been running fine for a month and a half after the tune. Plus wouldn't it just do it right at the shift point? It continues to do it even after it shifts. It did the same exact thing to me when I first bought the car and all I had to do was clean the MAFS. I pulled the MAFS and sprayed the hell out of it with cleaner and it still does it. Can a MAFS go bad?
Old Aug 2, 2010 | 06:30 AM
t72ss402's Avatar
Check your plugs and plug wires. My car was doing the samething and it was found that I had a plug that was bad.
Old Aug 2, 2010 | 09:10 AM
thunderstruck507's Avatar
could it be starving for fuel?
Old Aug 2, 2010 | 12:14 PM
omarrakeen's Avatar
^^ what he said. but is it at all gears? i had the exact same issue on my 1996 V6 when am at wot it wont shift to 2nd but would rev 5-6 times before shifting also happens at 3rd some times..ive been told its my tranny solenoids...never got the chance to change them..you should check that too. any engine codes?
Old Aug 2, 2010 | 06:56 PM
tg580's Avatar
its not throwing any codes. I'll check the plugs and wires.
Old Aug 2, 2010 | 08:40 PM
chad rock's Avatar
if it has timing tuner that could be it .if it doesnt probably crank sensor
