squeaking noise from engine
Old Jan 21, 2004 | 06:43 PM
axe's Avatar
axe
Question squeaking noise from engine
Starting yesterday I've been getting a squeaking/bird chirping noise under the hood of my '99 Z28 (no actual birds - I checked . The noise is there at idle (can't hear it off idle - engine might be drowning it out tho). Listening to the idling engine it sounds like it might either be the water pump or the power steering...? The power steering was a tiny bit low but filling to spec didn't change the noise. Car has ~50K miles. The car has a power steering cooler but has been on the same PS fluid and engine coolant for years.
Any advice? Any easy way I can test the accessories or narrow it down?
Thanks!!
Old Jan 21, 2004 | 06:54 PM
Steve1969LS1's Avatar
Hmm.. sounds sorta like a bad tensioner..
Old Jan 21, 2004 | 07:51 PM
MM98's Avatar
Mine too had that chirp like noise to it... Wound up being the idler pulley.. I believe GM has a bulliten out on those if I'm not mistaken.
Mike.
Old Jan 22, 2004 | 02:04 PM
ZR2877's Avatar
As MM98 said the is a bulliten out on it. If you would like let me know I have the number written down . You could do what I did and spray a little WD-40 or some lube on it. If it stops then you know thats it. I had that same chirp.
Old Jan 22, 2004 | 02:14 PM
TaTommyWS6's Avatar
Remember there is also an idler and tensioner pulley for the AC. You can always remove the AC belt for a moment to check if it is one of those making noise. Otherwise it is difficult to tell...
Old Jan 22, 2004 | 02:58 PM
axe's Avatar
axe
So last night I pulled the belt and fiddled with all the pulleys. Everything seemed ok except for some squeaking from the alternator pulley. I was pretty surprised at that... As I needed the car to get to work today I just put the belt back on thinking I'd buy/order an alternator today but now the noise is gone! :-/
I don't really wanna drop $100-$200 on an alternator without this really being an issue... Maybe it's just the belt that was making noise (the belt is pretty chipped and cracked) and I put it on backwards so now it's quiet? D'oh!
axe's Avatar
axe
Thanks for the replies, btw!!
Old May 20, 2004 | 10:40 PM
z2898ls1's Avatar
i have a 98Z28 and my alternator squeks does anybody have an idea to stop it with out having to buy another one
 Michael S. Palmer
Old May 20, 2004 | 10:51 PM
zchgla's Avatar
ya...i get a squeaking chirp and i dont know what it is either...grrrrr
Old Nov 6, 2004 | 04:29 PM
jrtf83's Avatar
sorry to revive a really old thread but i have a similar problem, except mine is high pitched and constant, i dunno if you guys's "chirp" is the same deal. And mine gets worse when the car's hotter and with higher RPMS.
Old Nov 14, 2005 | 11:30 PM
juiSSed1172's Avatar
I hate bumping old threads like this, but does anyone have the TSB for the idler? My car is chirping at idle..
Old Nov 15, 2005 | 12:06 AM
The PAT WS6's Avatar
i had same problem, replaced both belts and all was good
