ls1 oil problem
Old Aug 3, 2010 | 04:09 PM
marland speed inc's Avatar
Default ls1 oil problem
my friend has a 383 start up is 80 crusing is 65 when he mashes the gas it starts to drop after about 3 seconds he does have a hv pump you think he is sucking pan dry?
Old Aug 3, 2010 | 04:12 PM
DCC!!'s Avatar
is he low on oil? or not have it totaly full for the pan?
what is the oil pressure at idle?
Old Aug 4, 2010 | 06:22 AM
brian_rs/ss's Avatar
who installed the pump/pick up? they might have pinched the pick up o-ring.
also what is the idle pressure when the motor is hot?
at 209 degrees mine idles at 42 ish and WOT is around 65. now when i first punch it, it will dip for a second then build back up to 65 or so. i would say run the car up to temp and maintain it there for about an hour or so. making sure the oil is nice and hot. this will give you the most accurate/consistant reading. then punch it and take note.
btw what oil is being used?
