243's
Old Aug 15, 2010 | 08:50 PM
h8tulooze's Avatar
Default 243's
How do I know if my valves are sodium filled or not?
Old Aug 15, 2010 | 11:28 PM
180ls1's Avatar
try the internal engine section.
Old Aug 16, 2010 | 11:05 AM
incbed's Avatar
only the Z06 243 heads came with the Sodium filled valves,,which would have also came with the yellow beehive springs.
If your 243 heads have just regular factory beehive springs that aren't yellow then no they are not sodium filled.
Unless someone has changed the springs???
Also I have noticed that sodium filled valves will have a light greyish almost white apperance to them after being used.
hope this helps
Old Aug 17, 2010 | 05:19 PM
brian_rs/ss's Avatar
weigh them.
Old Aug 17, 2010 | 07:27 PM
djfury05's Avatar
hope this helps
there are other 243 heads with the yellow springs that did not have the sodium valve springs.. gto's did
Old Aug 17, 2010 | 07:35 PM
^exactly which is why you have to weigh them.
Old Aug 17, 2010 | 07:43 PM
djfury05's Avatar
bingo
Old Aug 18, 2010 | 09:16 PM
h8tulooze's Avatar
Mine came with Yellow Beehives and they are 4-15/16 in length.
 Michael S. Palmer
