whats up with pulleys??
Old Jan 23, 2004 | 04:28 PM
KALEL's Avatar
Arrow whats up with pulleys??
since no one would answer my question i figured i start a new post whats the difference in the percentage of underdrive (i.e. 10% vs 25%). ive seen a crank and alternator pulley set and a "special machining required for use w/ SLP chain" is this only for that chain or is it more of a necessity??
Old Jan 23, 2004 | 05:49 PM
98SS Blackattack's Avatar
The crank pullies are 25% underdrive. The alternator pullies are 10% or 25%. I would just keep my stock alt. pulley. The undredrive alt. pullies can cause low voltage situations. The machined ones are for double roller timing chain kits.If you have a stock or single timming chain you dont need one. ASP is the most proven out of the bunch. Tony
Old Jan 23, 2004 | 08:13 PM
soundengineer's Avatar
machining is for if you have a c5....and a double chain by slp..
no machining necessary on ls1 in camaro and birds
Old Jan 23, 2004 | 09:20 PM
KALEL's Avatar
in other words a crank pulley is what i should get...just want to make sure i dont make newbie mistakes
Old Jan 23, 2004 | 09:24 PM
jrp's Avatar
jrp
SN95 Director
yes, crank pulley is all you need. im running the ASP and dual rollmaster chain w/o problem, no shimming.
Old Jan 23, 2004 | 10:28 PM
KALEL's Avatar
so what kind of rwhp should i expect? i know its not too much
Old Jan 23, 2004 | 10:35 PM
jrp's Avatar
jrp
SN95 Director
from the pulley not much, its gains show up on the track more so then the dyno.
