3.8 multiple misfire helpppppp?
ive replaced the plugs, wires,all three coil packs and had my ignition module tested at two different places and was told it was good 8 times ,also replaced my cam position sensor and no luck whats next?
Here are my thoughts. What are the things you need for ignition? Spark, air, fuel, and compression. I think you eliminated the spark from the equation, so it might either be fuel, air, or compression.
Might wanna check the fuel injectors and the compression of the missing cylinders.
Let me know if you find anything.
