GTO Ignition cylinder failure...
Old Aug 28, 2010 | 12:56 AM
pokerfreak07's Avatar
Default GTO Ignition cylinder failure...
One day after work, i got in my 04 a4 gto, stuck the key in, and it will not move a mm... did some research and found out about the dreaded ignition cylinder probs...also- i had never had a problem before this occurance. My buddy started taking it apart as said in... http://www.ls1gto.com/forums/showthread.php?t=184864 but when we tried to turn the key which should remove the ignition cylinder, the key STILL WOULDNT TURN-so we couldnt get the ignition cylinder out... im really stuck..any help is greatly appreciated! I wrongly posted this in another section...mods feel free to delete the other.
