LS6 Intake or shorties???
Honestly though, you won't see much of a gain from the intake either on a stock motor, stock manifold car. Dollar for dollar ET wise (if that's what you're looking for), you'd probably get a better gain out of some drag radials if you don't already have them.
Of the option between the shorties or intake, if you ever plan to mod the motor, get the intake....
LT's here in cali. put it this way, your gonna pay the same price for shorties as you are for pacesetters and at least the pacesetters will give you a better plateform to work on then the shorties will.
you'll need both ls6 intake and LT's to get the most out of 80% of the cams out there. the biggest you can go safely and pass cali smog is 224 114 but you'll want headers for that.
I know I've been searching on a budget as yourself. In a way I'm leaning towards shorties but in the long road I want to hit as close as I can to 375 at the wheels running NA and shorties isn't going to cut it. I'm about 320 at the wheels now through an A4. Shorties probably would bring me between 325 to 330. Then what
LS6 intake, from what I've read, it isn't worth it unless I decided to go with a heads/cam package.And there again, I'm screwed with the headers unless I go mild. And in that regards, I won't hit 375.
I would expect 350 would be the max you could see if you went that route. Maybe alittle less.
But if you wanted a mid 12 second car and leave it at that. . . .not concerned with high HP then me personally would go that route.
However if you feel the need for speed and more power, then shorties = BAD!!! Get LT's if you can.
My advise would be to do the smaller stuff first. Go ahead a get the LS6, it's cheap (especially if you install it yourself, and even cheaper if you find one used), home port your TB (if you havent allready), install a cutout (cheap as hell). Then by this time you should have made up your mind about playing with emissions.
Hopefully, then, you come to your senses and stop giving a ****...buy the LT's then move on to the bigger more expensive things (like heads and a 224 114) In that respect, you may not be able to pass a visual (very easy to get around) , but you should pass the sniffer no problem. Good Luck to you.
