Help! where do these vacume lines go??
Old Sep 4, 2010 | 09:52 AM
ls1curt's Avatar
Default Help! where do these vacume lines go??
where do the vacume lines behind the intake go to? below is a pic of what i have. the engine in going in, in a couple hours so i need to know which lines go where.
thanks
Old Sep 4, 2010 | 10:17 AM
ILLWS6's Avatar
Ok I think the two above the bellhousing there go together somehow. Thats the best i can tell by feeling around back there. The other is the vacuum feed for the hvac. It tee's into some lines that go through the firewall on the passenger side.
Old Sep 4, 2010 | 10:28 AM
ILLWS6's Avatar
Here ya go.
https://ls1tech.com/forums/generatio...schematic.html
Old Sep 4, 2010 | 10:47 AM
ls1curt's Avatar
so something like this
Old Sep 4, 2010 | 12:11 PM
ILLWS6's Avatar
Ok man i'm really trying here but it hard to see. we can figure this out.
The FAT port on the back goes to the brake booster for sure. I dont know if that piece turns, i dont have a FAST intake, but mine points toward the drivers side. The line with the straight end on it goes to the nipple opposite the fat one like you have the arrow to.
Old Sep 4, 2010 | 12:31 PM
ILLWS6's Avatar
Now the small fitting on the manifold itself does not exist on my LS6 intake. I can't help you there. I think its just an extra vacuum port.
That last line goes here:
Old Sep 5, 2010 | 06:18 AM
bene's Avatar
Trunion King
Okay the one on the right is for your A/C vacuum line, connects to the small port on the right and the one on the left is for your AIR system. IIRC, there is a T fitting that connects to the A/C vacuum line.
