Power Steering Pump
Old Sep 5, 2010 | 11:06 AM
lil-bit's Avatar
Default Power Steering Pump
My car is making a loud screeching noise when it is parked and the wheels are being turned. I had someone turn the wheel while i looked under the hood and the power steering pump vibrates really hard while the noise is going. You think the its just the pump going bad? Thank you.
Old Sep 5, 2010 | 06:29 PM
Element's Avatar
More than likely, if it's not low on fluid.
Old Sep 6, 2010 | 08:34 PM
lil-bit's Avatar
Thank you, yeah i checked the fluid and it was full . It looked like coffee but it had fluid
Old Sep 6, 2010 | 10:48 PM
SOMSS's Avatar
Get yourself a new power steering pump. I just installed a Turn One pump, it's really nice, no turn to hard for this pump.
Old Sep 6, 2010 | 10:51 PM
Sleeping's Avatar
Yup time for a new pump make sure flush the system the best you can
Old Sep 7, 2010 | 12:32 PM
lil-bit's Avatar
Awesome guys thanks for the help i appreciate it. As far as removing the pump i read i need a special tool to remove and install the pully for my car.... Any idea on that? Ots a 2000 ls1. And im going to get that pump if you dont mind me asking where you ordered from sir.
Old Sep 7, 2010 | 12:54 PM
mike171562's Avatar
You'll need a pulley puller, you can rent one from O'reillys
Old Sep 7, 2010 | 01:04 PM
KeithZ28ss's Avatar
I got a Turn One Pump too. I love it. Car has a much better feel to it now. The wheel is tight, feels more reponsive too.
Just Google Turn One Power Steering Pumps. I'd give you the link, but not sure about the whole posting links of non-sponsors and whatnot.
Old Sep 7, 2010 | 02:59 PM
lil-bit's Avatar
Thanks for all the info guys . Is there a special way to flush the whole system before i install the new pump?
Old Sep 7, 2010 | 03:34 PM
stubbs4's Avatar
can someone tell me how to get the pully off so i can get to the pump??? thanks
Old Sep 7, 2010 | 03:56 PM
SOMbitch's Avatar
A pulley puller but the pulley is a plastic POS and mine broke so I ended up with a nice billet turn one pulley...
Old Sep 7, 2010 | 04:10 PM
stubbs4's Avatar
i have a puller and the somebitch wont come off !!!!!!!!!
Old Sep 7, 2010 | 05:32 PM
SOMbitch's Avatar
Same here and then the sumbitch pulley cracked.........
Old Sep 7, 2010 | 06:12 PM
Element's Avatar
You have to use a power steering pulley remover, not a regular 2 or 3 jaw puller.
Old Sep 7, 2010 | 08:24 PM
S10xGN's Avatar
Yup, like this one (or similar)...
Old Sep 7, 2010 | 08:40 PM
Element's Avatar
There's that and then the collar-type setup...
Old Sep 9, 2010 | 03:05 PM
lil-bit's Avatar
I have one like that first pic with the little arms . Mine has three arms thoigh . Well i orderded that turn one pump. Sounds good and that guy jeff was reall nice so im going to tear apart the camaro tonight after work. Hopefully the pully comes off fairly easy. Thanks again guys for the info. Appreciated!
Old Sep 12, 2010 | 12:29 PM
lil-bit's Avatar
yeah the plastic pulley broke when i was removing it. good thing i ordered the new one with the new pulley.
Old Mar 12, 2011 | 06:43 AM
trans_am7935's Avatar
i used this one after i broke the lip off my crap pulley, just ordered a turn one pulley
Old Mar 12, 2011 | 11:32 AM
Zerokube's Avatar
also look into a write up from LS6427 about a really good ps cooler, im about to install mine after replacing the pump about 3 times in 2 years.
