Help on AIR vaccum hoses?
Just trying to figure out if i should cap the valve on the solenoid from the junction and call it a day or remove the whole solenoid and both vaccum lines and plug wherever the other vaccum line goes to which I believe is the back of the manifold correct? Does that solenoid serve a purpose for anything else which would give me a reason to leave it and the line going behind the manifold?
I did a search got mixed answers on if the solenoid on the drivers side valve can be eliminated and found some answers saying the vaccum hose to the back of the block needs to stay just cap the one from the junction...Just looking for a definet answer and what needs to be plugged if anyone has come across the same thing, i already plugged the hole in my lid so that is done
