SLP Ls6 Intake Help
Old Sep 13, 2010 | 09:51 AM
tranb000's Avatar
Default SLP Ls6 Intake Help
So bought the car with ls6 intake on. Found it leaking around the egr fitting. O-rings are bad. Put new oring in and still leaks. With the intake being rounded and the egr fitting it just doesn't seal. I don't know if there are missing parts or whats going on. Please help.
Old Sep 13, 2010 | 11:21 AM
Golf&GM's Avatar
LS6 intake with EGR sounds fishy to me. My guess is you a stock LS1 intake or someone tried to cut the LS6 intake for EGR and messed it up. Have any pics?
Old Sep 13, 2010 | 11:43 AM
tranb000's Avatar
I'll have to see when i can get pictures. From what i've seen slp made an ls6 intake with the egr. I've been told it is an slp ls6 intake.
Old Sep 13, 2010 | 11:51 AM
Golf&GM's Avatar
Sorry I completely forgot SLP offered those with EGR provisions.
Old Sep 13, 2010 | 12:24 PM
tranb000's Avatar
No problem. I'm just trying to figure out a way to seal it up. The head of the brass fitting pushes up through the inside of intake with an o-ring the way it was set up. But with the curvature of the intake the head doesn't sit flush so the oring pushes outside of the head of the brass fitting.
