12573572 intake
Old Sep 14, 2010 | 04:17 PM
rielcrazy's Avatar
Default 12573572 intake
Looking at buying a ls6 intake with this P# 12573572. I've read somewhere that it does not have the same throttle hookup screw holes since it is off a z06 supposedly (which is drive by wire). Anyone know if I will have to do any mods to put this on my 98 ls1 ta m6? I know about the EGR delete but other than that will I have to add some nuts to the intake to hook on my throttle cable holder plate?
Thanks
Old Sep 14, 2010 | 04:20 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
If the intake you buy doesn't have the little bracket on the side for the throttle cable, just transfer it over from your LS1 manifold.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 14, 2010 | 04:22 PM
rielcrazy's Avatar
ah, so the hookup for the plate will still be there (the brass nuts built into the plastic to attatch it) I have my old one and can move it over no problem, was just worried the brass nuts to bolt it to might not be there.
also, anyone know if this ls6 intake, performance wise, is any different from other ls6 intakes? I read 1 post where someone claimed it made less hp, which makes no sense to me.
