ASP pullies
Old Jan 27, 2004 | 06:48 AM
DEEZ98Z's Avatar
Default ASP pullies
How many of you are using the complete kit? LG sells a complete kit... do I need the whole kit or just the crank pulley
Old Jan 27, 2004 | 07:29 AM
GM Muscle's Avatar
I used a complete kit. It's cheaper if you buy everything togethor. My kit was from another vendor so I didn't get new power steering fluid with mine nor did I change my fluid after the install. If you want to do just the crank pulley you will still need belts and a new crank bolt so you might as well get a complete kit with a alternator pulley too.
Old Jan 27, 2004 | 06:01 PM
WILWAXU's Avatar
Many of the sponsors sell kits. It's a good way to go. You get everything you need for the install, basically a bolt and belts. Thunder hooked me up many years ago with mine. Still going strong
Old Jan 28, 2004 | 11:42 AM
DEEZ98Z's Avatar
Hey Cheif So are you using the crank pulley only? The kit I was looking at also has the powersteering, a/c and alt pullies.
Old Jan 28, 2004 | 06:24 PM
WILWAXU's Avatar
That's Chief,
No, I'm talking about a kit many sponsors put together with everything you need for install. I run only the ASP crank pulley.
Old Jan 28, 2004 | 08:17 PM
DEEZ98Z's Avatar
That's Chief,
Ha ha, I was typing too fast Thanks for the info
