95mm T/B 102 Intake Problem on LS1
The T/B does not cover the intake O ring on the bottom of the T/B, it is clearly visible for about 1/8" and as such will never seal. The T/B needs to be about 1/4" longer to fully cover the O ring, Has anyone had this issue? Do i need to use a 102mm T/B only.
The PTM 95mm T/B was a TSP suggestion! mmmmm
Also the injector holes on the intake had to be relieved to allow my 42lb injectors to fit, wtf, thought this was a performance intake, and as such surely engines it will go on will have bigger injectors fitted, whats up with that?
