Need some expert help ASAP
Old Oct 1, 2010 | 08:52 PM
LT1TA's Avatar
Default Need some expert help ASAP
My car stalls when i push in the clutch. when coming to a stop, I press in the clutch and move into neutral. When i push in the clutch, the gas is killed (naturally), and the rpms drop and go back to idle. Well, now my idles drop and instead of going back to 900rpms like it was tuned to go to, it stumbles at 2-300 rpms and then dies. When cold starting, it will hunt for idle very bad but it would idle fine once it idles for a few. But if you push in the gas it will drop a little before it goes to idle. But if the clutch is pushed to get into 1st or downshift to 2nd from 3rd, the car will stall. HELP x20!!!
Old Oct 3, 2010 | 11:25 AM
LT1TA's Avatar
Bump for sunday
Old Oct 3, 2010 | 11:31 AM
kinglt-1's Avatar
check the iac and verify it is clean and not carboned up.
