Getting the P0135 02 sensor code!
Old Oct 8, 2010 | 09:36 PM
LPE 007's Avatar
Default Getting the P0135 02 sensor code!
01 SS with longtube headers, I am getting the P0135 02 sensor bank 1 code. I researched and found it is common with longtubes. Any long term issues to worry about? I have a scanner, and the problem is intermittent. Thanks.
Old Oct 8, 2010 | 09:40 PM
senicalj4579's Avatar
Its not one of the common codes with headers. Whenever I got that code it meant my o2 sensor was toast. Its time for a new one and let the games begin
Old Oct 9, 2010 | 08:48 AM
omarrakeen's Avatar
seriously?! am having bank 1 sensor 1 and insufficient activity on bank 2 sensor 1 should i change them?! i posted this and no one replied...to the OP sorry to hijack
Old Oct 9, 2010 | 10:18 AM
Domesticated Euro's Avatar
Usually if you have O2 sensor codes for the front sensors, you could have a problem somewhere else in your engine if it is pretty much stock. When you start modifying it with heads or cam or something else, that can also ruin your O2's. Most aftermarket cams arent good for your o2's. I went through 3 sets in my car with a Comp Cam (middle range for performance). I even had a great tune too. In my case the best thing to do is to have it tuned without O2's which will work just fine but not have quite as good gas mileage. Just remember that if you DO have another problem, (vacuum leak, fuel pressure regulator leak, etc.) then tuning without your O2's will not work.
Hope this helps,
Luke
Old Oct 9, 2010 | 10:40 AM
Darkman's Avatar
Based on the trouble shooting procedure for P0135 the most likely causes are a bad O2 sensor or the wiring that connects it to the harness.
If your modified car starts eating front O2 sensors on regular basis your tune is off - aftermarket parts do not kill O2 sensors - inefficient combustion does.
Old Oct 9, 2010 | 02:21 PM
omarrakeen's Avatar
ok my car has only lid and exhaust and am getting low voltage on bank one sensor 1 am swapping the front with my old rears and see what will happen.thanks for the info and sorry for the hi jack
Old Oct 9, 2010 | 03:02 PM
Darkman's Avatar
The front and rears are not always interchangeable - might want compare part numbers.
Old Oct 9, 2010 | 05:15 PM
You should word your codes desciption correctly so we know what your talking about. (P0140,P0160,P1133 ,P1153 ARE COMMON)
Did you mean your having codes p1133 Insufficient Switching Bank 1 Sensor 1? Whats your codes?
 Michael S. Palmer
Old Oct 9, 2010 | 05:16 PM
Front and rears are the same. Trouble shooting by swapping them is perfect. Thats what I do
Old Oct 9, 2010 | 07:27 PM
ShevrolayZ28's Avatar
Front and rear sensors are interchangeable. the only difference is wire length.
LPE007,
P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor1). This is unexpected, unlike the insufficient switching code, and should be looked into further. Are you sure you didn't melt a wire? One of the wires supplies power to the sensor's heat element. Put a multi meter to that wire and see if it's seeing power with the key on/engine off.
Or an easier way is to swap sides and see if the code moves with sensor.
There's some decent advice in this thread...and some....
Old Oct 10, 2010 | 02:59 PM
omarrakeen's Avatar
here are my codes i tried asking here but no one answered. i really need help for this my MPG is a bit down. here are my codes.
PO131: low voltage bank 1 sensor 1
PO134: circut insufficient activity bank 1 sensor 1
PO135: heater performance bank 1 sensor 1
PO154: circut insufficient activity bank 2 sensor 1
PO155: heater performance bank 2 sensor 1
thanks.
EDIT: i know rears and front are interchangeable for sure to whom who said it isnt.
Old Oct 10, 2010 | 03:13 PM
Darkman's Avatar
I did not actually say it isn't but I said that some are not interchangeable based on the fact that mine (CTS-V LS6) have two different and dissimilar part numbers and two different connector types. I have already been corrected (and ridiculed) for not knowing the sensors themselves might actually be the same. I apologize if my suggestion that you verify part numbers caused any inconvenience.
Old Oct 10, 2010 | 04:41 PM
Monte LS....1's Avatar
My experience on many different vehicles is that if the code for a heater circuit fault shows up, a new O2 sensor has always fixed it.
Old Oct 11, 2010 | 04:09 AM
omarrakeen's Avatar
you dont have to be sorry for that lol its just a correction no more no less. thats the point of the tech anyway
Old Oct 11, 2010 | 04:30 PM
omarrakeen's Avatar
i posted the correct codes...any one to help me out? seems my O2s arent functioning
Old Oct 11, 2010 | 05:52 PM
Darkman's Avatar
See attached.
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 14, 2010 | 04:07 AM
omarrakeen's Avatar
mmmm i still dont get it? and i dont have the scan tool at the moment any other solutions? i will replace my rear O2s with the front and see if it solves the problem..thanks.
