installing fabricated valve covers, what to do with pcv?
Any ideas, pictures, and part numbers are greatly appreciated
Randy
Randy
Using the LS6 Valley Cover does allow you to eliminate all the PCV Hoses running to the Valve Covers.
I have the LS6 Valley Cover as well as a RevXtreme Catchcan. Here is a picture of my setup.
You can see the PCV Valve connected to the Intake Manifold directly behind the TB. It then attaches to the side of the Catchcan.
The top of the Catchcan is connected to the port on the LS6 Valley Cover directly below the PCV Valve.
As you can see, nowhere is the PCV System connected to either Valve Cover. If you choose not to run a catchcan the hose from the Valley Cover containing the PCV Valve would simply loop around to the Intake Manifold.
The only hose you'll have going to either Valve Cover will be from the Throttle Body to the Passenger Side VC. Which you can also see in the picture provided.
Using a Valve Cover Breather is also an option, but using Aftermarket Valve Covers doesn't rule out use of a PCV System.
if you dont have it.. you need a Breather
For some reason I thought the Hose from the TB was simply a Vent Tube. But, of course, it has to due with Crankcase Ventilation.
Anyways, long story short...
You'll need at least one port on the Passenger Valve Cover to connect this Hose to if you want to run a PCV System. Other than that, no other hoses are necessary.
Thanks for the correction.
This is just an idea, I've never done this, so maybe someone else can chime in on whether or not this would work...
Couldn't you simply add a fitting to the Oil Filler and run the Hose from the Throttle Body to it?
You'd still be allowing for ventilation on the same Valve Cover. It would simply be in a slightly different location.
This along with the LS6 Valley Cover would eliminate the need to port the Valve Covers themselves and you could still run a proper PCV System.
Again, I have no experience with this. Just thought I'd throw that out there.
Good luck, man.
Good luck, man.
Again, I've never done this, but I don't see why it wouldn't work.
If i go with fab valve covers can i just run a hose from each valve cover to a catch can or will the ls6 mod be needed too?
Get one with a removable pcv valve so you can remove it.
Just Google Billet PCV breather.
