Bogging When Accelerating Out of Turns
Old Oct 18, 2010 | 12:34 AM
98z28CamaroJG's Avatar
Default Bogging When Accelerating Out of Turns
Not sure which section to put this, so this is in a few different sections, but i autocross my car and need this fixed asap. So within the last few weeks i've noticed my car has a tendency to bog pretty bad when trying to accelerate out of turns. I'd downshift to second, go into the turn, and midway through to coming out out the turn, i'd give it gas and it wouldn't do anything then suddenly catch, studder a bit and go. Any idea what could cause this? Seems to be more prevalent taking right turns and in second gear, however that could just be me being over-thinking it a bit. Recently installed LS6 Intake Manifold, Ported and Polished Stock LS1 Throttle Body (that sticks a little when starting to give gas), and K&N FIPK.
Old Oct 18, 2010 | 12:50 AM
kmracer's Avatar
check out the throttle position sensor.
noticed anything driving around town?
Old Oct 18, 2010 | 02:51 AM
69cutlassrkt's Avatar
you think it might not be getting enough fuel when you make right turns? mine would like start to die then all of a sudden take off once it started getting fuel, when I would have the pedal mashed down making a turn on half a tank.
Old Oct 18, 2010 | 05:08 AM
Which is the TPS? the one closest to the front of the car? As for the not enough fuel part, i figure it should get more than enough with the Racetronix/Walbro 255 fuel pump i got put in last month...
