Quick Open Headers Question
Old Oct 19, 2010 | 08:28 PM
Befwazie's Avatar
Default Quick Open Headers Question
Okay so right now im running open headers with the stock exhaust manifold and cats. So my question is that will it hurt my engine at all? Like I mean I heard it can warp your exhaust valve but there is no proof it ever happening, and also if you look at it this way I have the y-pipe inlet 1 1/2 inch away from the cats outlet on both sides so it isn't completely "open"
Only reason why it have it open is because im getting a new I pipe cause mine is dented and there is a small slit from me running over rocks and replacing it tomorrow.
And here is my 2 cents on the valve warping from cold air. the cats heats up really hot so the theory of it sucking up cold air, wouldn't the air just heat up because it passes through the cats?
What is your guys input?
Old Oct 19, 2010 | 09:37 PM
2000***camaro***ss's Avatar
im not sure man i could never figure out how to run headers and manifolds at the same time
Old Oct 19, 2010 | 09:40 PM
Befwazie's Avatar
What? Headers and Exhaust manifolds are the same thing?
Old Oct 19, 2010 | 10:49 PM
conor.davis's Avatar
headers and exhaust manifolds 2 different things.
sounds like you already have your mind made up anyways.
probably wont damage anything if your just doing it for a day.
Old Oct 20, 2010 | 09:23 AM
1964_442's Avatar
headers :
manifolds:
Old Oct 20, 2010 | 09:43 AM
Element's Avatar
Actually, there is proof of valves warping on open stock manifolds, but as long as you have cats, you should be fine.
Old Oct 21, 2010 | 12:53 AM
69cutlassrkt's Avatar
I have read before that the exhaust valves warping is caused by the engine running lean with headers causing the exhaust valves to heat up and when the fresh cooler air comes in it cause it to warp. I would run open headers.
Old Oct 21, 2010 | 01:04 AM
Lambert695's Avatar
I think its more of an issue with 2-stroke engines. Usually 4-strokes dont have the issues of that. People run open headers all the time. I personally dont think the car likes it and it runs worse but this is an opinion from my experience.
 Michael S. Palmer
