Engine removal lift points?
Pictures would help greatly.
thanks.
-Don
http://www.michiganspeed.com/enginepull/index.html
Thats only for moving it around...never installed one through the top so there might be better spots, but probably your best bet.
Ide remove the intake if I were you, unless youre using a spreader bar. The angle the chains run at get kinda close, and its only plastic.
J.
-Don
I used an engine tilter. At the front of the engine I did use a spreader bar to keep the chains away from the intake. Chains were fastened to the front of the heads with extra bolts. At the rear, I swapped out 2 stock bellhousing bolts for some longer ones and connected chains to either side of the bellhousing. A lot of chains and connections, but I wanted to move my LQ4 and NV4500 together, safely.
