P/S pump delete?
If it was optional than either an idler pulley or a different drive belt would be used.
Also, are you using Corvette or F-body accessories?
The engine/trans is out of a '99 Firebird. I am going to use the A/C(seperate belt), and the stock (low mount) generator.
I guess I could remove the pump part and leave the pulley and housing or could I just get a shorter belt(not sure about all the looping)?
