Anyone Installed an Edelbrock Carb Kit??
Old Oct 31, 2010 | 03:57 PM
DSGB_4_life's Avatar
Question Anyone Installed an Edelbrock Carb Kit??
I want to change my car from EFI to Carb. I think it'll sound great I’m sure it won't hurt my performance and where I live I haven't met anyone else with a Camaro that’s done it. Is there a bunch more money/work involved other than buying the kit and putting it on? If so what all needs to be done in order to make the kit work correctly? I want to know what I’m getting into before I actually buy it (don't want to go in blind) so any help would be great...Thanks Yall
Old Oct 31, 2010 | 05:15 PM
Fastdriver1992's Avatar
do it. easiest setup u could ever do take a look @ my car. its an easy conversion. the new msd box is plug and play. picks up the cam and crank sensor. u can program your own timing. the hardest think is the carburator hieght and removing the factory ecu.any other questions plz dont hesitate to ask.
http://i807.photobucket.com/albums/y...e/PIC-0127.jpg
http://i807.photobucket.com/albums/y...e/PIC-0028.jpg
http://i807.photobucket.com/albums/y...e/PIC-0029.jpg
Old Oct 31, 2010 | 07:40 PM
S10xGN's Avatar
Originally Posted by Fastdriver1992
...u can program your own timing...
Just to clarify (again), only the MSD box is programmable, the Edelbrock box uses timing pills and is NOT programmable. The MSD box must be purchased separately and is not part of any kit like the Edelbrock...
Old Oct 31, 2010 | 07:56 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Just buy the intake and get the MSD 6010 box like S10xGN said
I've done it on my fourth gen and couldn't be happier. Hit up the Carb forum and read up on the threads in there
Old Oct 31, 2010 | 08:48 PM
agreed!! idk about hood clearance so i would go with the low edelbrock manifold instead of the victor jr. but if u can make the victor jr fit go for it, victor jr is a much better manifold
http://www.summitracing.com/parts/EDL-71187/
Old Nov 1, 2010 | 10:12 AM
speedtigger's Avatar
Old School Heavy
I hear this statement a lot. It is not a case of better or not. It is case of powerband. The Performer RPM is more low end torque oriented while the Vic Jr. Is more high RPM oriented. The Performer RPM makes more power than the Vic Jr. below 5,000 RPM while the Vic Jr. makes more power above 5,000 RPM on 5.7 - 6.0 motors. It is just as simple as that.
The Perform RPM also has better drive-ability.
Old Nov 2, 2010 | 07:05 AM
Thanks Yall for all the help. I'll put pictures up once i buy and install the kit. Thaks again
