used FAST 92mm intake
Old Nov 17, 2010 | 07:33 PM
OMGls1jz's Avatar
so does the fast 90 or 92 bolt on to a ls1 fbody without modifications? or does it need some work like the 102? i've read breifly that the 102 fasts require different injectors and fuel rails?
Old Nov 17, 2010 | 09:12 PM
reeperz28's Avatar
The 102 needs ls2 style fuel rails and all the hoses and fiTtings with it its another 300 on txspd and if you get I believe a 95or96mm and up you have to modify your waterpump due to it large size its in the way
Old Nov 18, 2010 | 04:57 AM
SS4Luck's Avatar
im pretty sure i saw somwhere the mezuire (i know that has to be spelled wrong) electric water pump clears the Fast 102 so you dont have to grind on the pump
Old Nov 18, 2010 | 08:09 AM
lemons12's Avatar
You need he new fast rails and spacers, stock injectors will work fine. Fast rails look soooo much nicer anyway, nice upgrade.
Mine fit on my car with zero modification.. I have coils relocated under cowl and it fit with those also.
Old Nov 18, 2010 | 11:12 AM
reeperz28's Avatar
My bad I looked back on that and it was the vettes stock water pumps that was giving problems
Old Nov 18, 2010 | 11:45 AM
lemons12's Avatar
Correct, I think gtos are also having a problem with them, could be wrong in that though.
Old Nov 18, 2010 | 12:34 PM
X-ray's Avatar
Originally Posted by lemons12
102 being too big for a stock cube ls1 was shown to be false months and months ago..
You will pick up less HP but more tq with a 102 than a 90 or 92.. at least from the majority of swaps I have seen, including mine. The runners were changed, I am sure that is the reason.
Yep, same with the throttle body. 102 TB with a 102 intake will gain a little power/torque everywhere over a 92 TB.
Old Nov 18, 2010 | 12:40 PM
lemons12's Avatar
You also have to remember though, the 102 tb is a bit harder to tune also.. and honestly most people don't even need a 92tb let alone a 102.
