quick question...
Old Nov 12, 2010 | 10:14 AM
cheston11's Avatar
Default quick question...
ok so i am installing a fast 102/102 set up on my 02 firechicken. i am new to this and the job is no problem but i am also installing a big MAF to run with the set up. this car is my only way of transportation and i know i need a tune but will installing these parts make it not run until i get it tuned? i just want to make sure i can get to a shop w/o towing it because i would be screwed if i get it all put on and it wont start up bc of the intake difference.
oh and i am running the front strut brace and the manifold is pretty big. am i gonna be able to keep the brace? i already know i gotta take it off for install but i just wanna make sure i have the clearance when its all said and done
thanks guys
Old Nov 12, 2010 | 10:25 AM
djfury05's Avatar
it will have a very tough time running.. your better off putting the intake/tb setup on.. and using the stock maf until you get to the tuner.. once you get there, swap the maf on.. that's what I did at least
the only way to tell if you'll be able to use the STB is to get it installed and then see if it fits
Old Nov 12, 2010 | 10:29 AM
cheston11's Avatar
ok cool i appreciate it man. i figured i might have to do that, no biggie. should be fun though lol
