broken oil press sending unit
Old Nov 27, 2010 | 04:14 PM
Z06 Steve's Avatar
Default broken oil press sending unit
ok did the LS6 swap and broke this damn thing I was super careful and it still broke WTF!!! what causes them to snap?? maybe the brake booster hose wraps around it when the intake is removed?? any ideas
anyway im pissed
Old Nov 27, 2010 | 04:16 PM
sjsingle1's Avatar
i was VERY careful too..........broke it anyway............welcome to the club
Old Nov 27, 2010 | 04:20 PM
cadenwade's Avatar
some times the wire that plugs into it runs over the top of the brake booster hose and you have to reach back there and unplug it or you will brake it every time (happened to me a few times LOL). Is has not happened to me sense I found this...
Old Nov 28, 2010 | 12:05 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'd say the plastic gets brittle
Old Nov 28, 2010 | 01:46 PM
00'WS6Rocket's Avatar
I changed it twice and bith times it broke...... Now im driving with check gauges light on, too pissed to take the mani back off to change
Old Nov 28, 2010 | 05:11 PM
bayer-z28's Avatar
The sender is between the intake and the brake booster line.. The intake has to be turned counter clockwise to get it away from the sender.
Old Nov 28, 2010 | 08:40 PM
Golf&GM's Avatar
After I get the intake loose, I unplug the sensor then reach around the back of the intake and lift the brake booster line up and over the sensor as I pull the intake forward. Why GM but a massive fragile sensor right there and wrapped the vaccum line around I'll never know.
Old Nov 28, 2010 | 11:48 PM
01ssreda4's Avatar
I broke my stock sending unit while removing my intake while the engine was on an ENGINE STAND. They are just friggen brittle man.
Old Nov 29, 2010 | 10:21 AM
Hemi2Slo's Avatar
I broke mine too. Nothin but an aggravation. Gotta make sure the wire is disconnected. then I found the best way is to keep your hand in between the intake and the sensor while tryin to set it in place.
