ARH header install problem.
Old Dec 12, 2010 | 09:16 PM
subarubill96's Avatar
Default ARH header install problem.
I have a set of ARH 1 7/8" race style long tubes headers going on my car. I have the drivers side header installed and it went in smooth as could be. The passenger side header on the other hand is giving me problems.
I have the starter out of the car and had previously had the engine tab ground off so I know these aren't the issue. The car has never been involved in an accident so I know thats not one of the problems either. I have a 2 post lift so I have the car plenty high enough.
The header gets "stuck" going in, one way it hits the bellhousing where the starter bolts up or hits the K-member when I turn it another way. I have tried to wiggle it in but its been to no success.
any ideas or anyone else have this issue?
Old Dec 12, 2010 | 10:07 PM
bucketlist1957's Avatar
Default Arh
I had a similar problem putting the passenger side in on my C5. I wound up putting it in from the top. I pulled the coil packs and valve cover. It hung up a little on my low pressure AC line but I pursuaded it past with a couple light whacks of a rubber mallet. Good Luck I don't know much about the FBody with an LS1. My old FBody has a 6 banger in it.
Old Dec 13, 2010 | 09:49 AM
9t8z28's Avatar
Call ARH.
Old Dec 13, 2010 | 03:21 PM
davidws6's Avatar
When I installed the first set on my 00TA, I had to take the bolt out of the R motor mount and jack up the engine a little.
That was with Mac mid tubes.
I installed my 1 7/8 ARH's after I had bought my car lift and during an engine upgrade.
Old Dec 13, 2010 | 05:34 PM
craZy28's Avatar
If I remember when I did mine I did MM at the same time,but I don't remember if I left the engine jacked up or not. The header went in with just a little bit of tweeking, other than pulling the starter out I didn't have to do any grinding or anything.
Old Dec 13, 2010 | 06:59 PM
luna123black's Avatar
I just did mine earlier this after noon. Passenger slide slid in with plenty of room drivers side was tight but a little push slid right in. I didn't have to remove the starter or oil filter. Didn't remove anything except coils. This was on jack stands about 20 inches high.
