Need help with oil pan question
Old Dec 15, 2010 | 01:14 AM
Mustang605's Avatar
Default Need help with oil pan question
What is the thing on the side of the oil pan for my ls1 it bolts to the side of the oil pan & it has a small tube kinda thing on it with a whole in it right above where the filter goes? I'm ready to fire my car up & don't know what this is..heres a pic of what I'm talkin about
Attached Thumbnails Need help with oil pan question-ls1-oil-pan-f-body-camaro-trans-am-ls1-2-6swap-oil-pan_110599816646.jpg
Old Dec 15, 2010 | 07:18 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Oil level sensor.
Old Dec 15, 2010 | 11:40 AM
Mustang605's Avatar
will it blow oil out? can I just cap it off or what?
Old Dec 15, 2010 | 03:36 PM
01ssreda4's Avatar
Oil level sensor is on the PASS side. The piece you are talking about is a pressure port. If its open it will spray oil out. The piece that comes stock has a hole in it but is casted solid down in the piece. It is common to drill through the cast, and tap for an aftermarket oil pressure gauge. However, the way it is stock, it is sealed.
Old Dec 15, 2010 | 07:57 PM
Paul Bell's Avatar
I stand corrected, thanks 01
