car isnt detecting misfire
Old Dec 28, 2010 | 01:47 AM
m6camaro's Avatar
Default car isnt detecting misfire
I have had a minor misfire (can only feel low rpms in 6th gear) problem that has slowly gotten worse. Now I can feel the misfire in all gears and all rpms. Problem is, the car is not throwing a code. What would cause the pcm to not detect a misfire? Every now and again it will say random cylinder misfire but never tell which one is misfiring. I have replaced wires and checked plugs. Coil packs or injectors maybe?
Old Dec 28, 2010 | 02:05 AM
omarrakeen's Avatar
how did u check spark plugs? id say change spark plugs too and see what happens from there. does it misfire at wot too? or only at low rpms?
Old Dec 28, 2010 | 04:03 AM
Q8-TECH's Avatar
does the car have egr?
Old Dec 28, 2010 | 10:22 AM
m6camaro's Avatar
I took all the plugs out and inspected them. The plugs only have 2k miles on them, the same as the motor. Hard to tell if it is missing at WOT, and no I do not have egr.
Old Dec 28, 2010 | 10:57 AM
omarrakeen's Avatar
alright then. go to fuel may be? fuel pump how is it? fuel filter? start with the cheapest stuff.
