Oil CAtch can location
Old Jul 14, 2012 | 03:52 PM
JoshuaGrooms83's Avatar
that sounds like a good alternative. I think a wiremesh sandwiched between chickenwire would work really good. a few layers of that at the top of the can and the rest will drip down as it accumilates.
Old Jul 14, 2012 | 06:07 PM
cookba's Avatar
i have mine under the passenger headlight. Everytime i change my oil i drain the can. easy access through the trap door and my Mike Norris can has a wing nut on the bottom to easily drain.
Old Jul 15, 2012 | 07:20 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'm a fan of a green brillo pad on the inside, myself.
Old Jul 15, 2012 | 08:36 AM
redtail2426's Avatar
mine is under the passenger headlight,and the bottom screw is easily accessed under the car,it sticks out like a half inch below the plastic.The farther from the engine you can get it the better.The cooler you can keep the can the better it will condense the incoming air/water/oil
Old Jul 15, 2012 | 10:02 AM
was was wondering about the green scratch pad. does it deteriorate over time or does the oil help to preserve it?
Old Jul 15, 2012 | 11:03 AM
dr_whigham's Avatar
The Scammer Hammer
I just change it whenever I drain it. They're like a dollar for 5 I think
Old Jul 15, 2012 | 12:26 PM
verytrue, just wondering how it handled for you. i might do that too.
