PCV Valves
Old Jan 15, 2011 | 01:49 PM
uLs1a's Avatar
Default PCV Valves
Well I did a heads/cam swap and the center bolt valve covers I got did not have the pcv valveand the rear drivers side valve cover, I wanted to see if anyone had the part number.
The top valve cover all the way to the left, the valve sticking out
I found this at my local Kragen store, but not sure if its the right one
http://www.oreillyauto.com/site/c/de...2180&ppt=C0023
Old Jan 16, 2011 | 08:39 AM
djfury05's Avatar
I've never seen that on these type of valve covers. Only a rubber grommet with an opening for the pcv plastic hard lines to pop into it.
Old Jan 16, 2011 | 10:32 AM
sjsingle1's Avatar
that looks like a truck cover
Old Jan 16, 2011 | 11:33 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Correct guys, that's not a F-Body valve cover.
OP, here's exactly what the stock LS1 F-Body PCV and piping should look like:
http://www.hotrodlane.cc/New%20LS%20...lace%20LS1.htm
Old Jan 16, 2011 | 11:40 AM
Paul Bell's Avatar
The illustration doesn't seem to show the tube into the right valve cover. Like somebody erased it off the paper lol. It's there tho.
Old Jan 16, 2011 | 02:35 PM
uLs1a's Avatar
Perfect, thanks guys
