Bung on rear of intake...removal
Old Jan 16, 2011 | 11:14 PM
sjsingle1's Avatar
Default Bung on rear of intake...removal
the plastic bung on the rear of the intake that holds the map sensor.......how do you remove that sucker???
Old Jan 17, 2011 | 04:08 AM
masterz28's Avatar
There is a clip over it you push that back and you pull up.
Old Jan 17, 2011 | 09:56 AM
sjsingle1's Avatar
not the map sensor itself.......the whole bung
Old Jan 17, 2011 | 11:00 AM
3rdgen92maro's Avatar
Good lock trying to get it out. It was a royal PITA trying not to break the intake. When i did it..i used 2 really small flat head screw drivers to pry around the edges. Theres 3 plastic clips that hold it in.
This is the piece your trying to remove right?
Old Jan 17, 2011 | 11:28 AM
sjsingle1's Avatar
thats it........the clip that holds the sensor down is broke.....i can get a bung from another intake......just need to know how to get em out.........so you did or did not get it out? anyone do it from the inside?
Old Jan 17, 2011 | 07:53 PM
I got it out with two small flat head screwdrivers.
