Lokar Throttle cable problem.
Old Jan 17, 2011 | 10:29 PM
tweakgames's Avatar
Default Lokar Throttle cable problem.
Hello all. I am wondering if anybody is having the same problem as me with their Lokar LS1 throttle cable.
The copper throttle stop at the end that connects to the throttle body arm doesn't seem to be wide enough and gets pulled out of its holes a little bit. Is this normal? Is there any way to fix this? I have been forced to just run the stopper on the outside of the TB arm and it looks really bad.
Thanks
~Tweak
Old Jan 18, 2011 | 07:03 PM
Top Fuel's Avatar
the hex portion of the stop is supposed to be on the outside of the throttle arm, if that helps
