deleted the pcv on my camaro ??
Old Feb 1, 2011 | 07:20 PM
ez money's Avatar
Default deleted the pcv on my camaro ??
i took the stock pcv system off my car and put a small filter on the back of the drivers valve cover and a breather filter on my oil filler neck and pluged off the other vents is this ok?? of should i run a cannister type system??
Old Feb 1, 2011 | 10:26 PM
garygnu's Avatar
it will allow more moisture into the crankcase.if it is not a all out race car keep the stock PVC system.GM engineers designed the stock system to keep moisture out of the engine which helps longevity of the engine.prostock uses a sealed pvc system.
Old Feb 1, 2011 | 10:38 PM
bayer-z28's Avatar
You can do the LS6 valley cover if you are just looking to get rid of the tubing. Otherwise just put the canister on there. There have been a lot of arguments about "vacuum leaks" on this topic.
Old Feb 2, 2011 | 07:47 AM
TransWS6Am's Avatar
+1 for LS6 valley cover.....
Old Feb 2, 2011 | 12:21 PM
98blackbirdta's Avatar
Brst thing I ever did, just chamge my oil more often
