Question on Cutout Wiring
Old Feb 1, 2011 | 08:27 PM
DUSTYWS6's Avatar
Default Question on Cutout Wiring
I just installed a DMH cut-out and I spliced into the cigerette lighter for the ground and the pink wire on the traction control switch for my power. When I turned the key to "accessory on" and I tried the cut-out switch, nothing happened except for a sound that appeard to be coming from the front of the car which I think was a headlight motor. I didn't start the car (it's in the air on jack stands), so pehaps the pink traction control wire would be ok once I have the car started and I'm at a higher voltage.
I did a search and didn't find much that said I shouldn't use the traction control switch for power, but maybe I need to find another power source? since I don't have a LED light that will drain my battery, I'm thinking about splicing into the cigerette lighter for the power.
Any help would be greatly appreciated!
Old Feb 1, 2011 | 10:38 PM
TankTheTurtle's Avatar
Yea, the cigarette lighter sounds like a much better idea. I can't imagine that there would be power to the tcs when the car isn't running..
