Intake manifold advice?
Motor is
418 ci
AFR 230cc v2 heads
248/254 - .615/.623 - 112 cam
morrel link bar lifers, yella terra roller rockers
forged bottom end
motor is going to be completely 12pt arp studed
1 7/8 kooks headers
I cant decide between a fast 102 (talked to tony mamo, heads and mani will be touched by mamo)
or super vic/vic jr w/ an accufab?
Ill spin this motor as high as it makes power (cam is advertised to 7500 rpm)
Ive searched and searched and have no idea
If so dont even think about the single plane combination.....you have to have a hoodscoop and the necessary room to mount a TB on top of the intake like it was designed for best results.
Trust me on this....I know alot of folks that wouldn't listen and sold there set-ups cheap shortly after when they gave up 40 ft/lbs to the FAST and didn't even make ANY more power. A good friend of mine tried it awhile back and spent alot of time and money to get nowhere (but kudos to him....thats real R&D!)
If you have a forward facing hood scoop on the car (or even a tall cowl scoop) and can funnel fresh air straight down the throat of that single plane it becomes a consideration.
Show me one hard running high powered combo with a front mount TB, 90' elbow, and a single plane! I really dont think you can unless its boosted and than who knows how much better it would be with a FAST and the same amount of boost.
Part of the problem is the elbow is too sharp and the air has to make a 180' turn to fill the front cylinders.
Also, a single plane really likes RPM....and over 7200 any hydraulic is really a bad idea (IMO).....valve control just gets compromised.....bite the bullet and go solid at that point.
C-O-M-B-I-N-A-T-I-O-N is king....screw it up and a bunch of parts that look OK on paper never pan out as well as you hoped.
-Tony
i saw a thread on YB with a 418 making stupid power with a single plane and thats when it crossed my mine. Looking back on it now it was a solid roller lol
FWIW im running a big cowl, with my stock cowl cut away so i would have put an accufab on top instead of the elbow.
fast 102 here i come lol
