92mm TB on 90mm intake?
Old Feb 6, 2011 | 10:05 PM
BlueBird346's Avatar
Default 92mm TB on 90mm intake?
Will installing a 92mm throttle body on a FAST 90 have any negative affects? Seems like it would create turbulence. Or should I buy a 90mm throttle body?
Old Feb 6, 2011 | 11:55 PM
cowboysfan's Avatar
it will create turbulence. get 90mm. or port match!
Old Feb 7, 2011 | 09:28 AM
Jon@Texas-Speed's Avatar
Not a huge issue with the difference in size. It will fit fine. If you are worried, just open the inlet on the intake. 1mm all the way around and you will be good to go!
Jon
Old Feb 7, 2011 | 05:31 PM
Jon
Thanks! Didnt think it was a big deal, but just wanted to be sure before I spent almost $400 on a throttle body.
